Firmware still at v0.08.00.08297-PN
Markwallwork0
Hi my PN hub 2 is still at the firmware version above . I checked with PN and they said it was still at the management platform is there anyway to get it updated or do I simply just wait . It’s not giving me any issues
3 REPLIES 3
Fixes: 246
Re: Firmware still at v0.08.00.08297-PN
Hi Mark,
Was that checked by serial number or just confirming that there is a Hub 2 on your account?
There was a major update programme about 18 months ago ... so it should have updated before now.
@bobpullen  - is this still your space please?
Markwallwork0
Hi this was confirmed by Plusnet via serial number . It is on the management platform but hasn’t been online for more than month as this was my spare router which I only connected a month ago after problems with my other one . From what I can see it has never received the latest firmware also never had it when I received this router at the end of 2023
@Markwallwork0
If the Hub two is on the management system you should be able to prompt a firmware upgrade by performing a factory reset.
With a paper clip or similar push in the factory reset hole, hold in until the light either goes off or green
HTH
