Delivery time for Hub Two router.
PeteL44
What's the delivery time on the router and/or does it fit through a letter box?!
6 REPLIES 6
Fixes: 388
Re: Delivery time for Hub Two router.
@PeteL44 Usually 1-3 days via Royal Mail Tracked24, and yes it does fit through a standard letterbox
why are you asking/
Fixes: 585
They are sent Royal mail 24H tracked. They are normally dispatched to arrive 2 to 3 days prior to scheduled install. You will get an SMS/Email when its dispatched. They are designed to fit through a standard letterbox but a lot depends on your postie, many won't even attempt to put it through...
@PeteL44
The box is around
195mm wide
40mm deep
430mm long
HTH
PeteL44
Thanks - I am having a "free" upgrade with my contract renewal - just want to make sure I'll be around when it's likely to arrive.  If it goes through the letter box even better!
Fixes: 388
You will be advised by text and/or email when it leaves the warehouse - the notification will include a tracking number.
mwwagain
Fixes: 4
To add my experience of ADSL to FTTP, the despatch is triggered ONLY once OR have confirmed the instal date.
For me PlusNet have been advised it is a 'two stage install' and reported that OR have said:
'First stage anticipated to finish by 19 Feb'
with the original install date I selected of the 20th being 'still reserved for you'
As such the hub had not been sent but was despatched manually instead - and duly arrived in 48 hours (Royal Mail on a Sunday !)
I guess I'll find out tomorrow if anyone turns up ....... certainly no 'digging' happened here.
