Accessing Hub 2 Hub Manager whilst in bridge mode?
mnsuk
New customer here. My service went live earlier today and I set up the Hub 2 in bridge mode with a TPLINK Deco M5 mesh. I followed the published Plusnet advice regarding bridge mode and the Deco manual to set up the PPoE link. it was all very straightforward and everything is now working.
I have a question though - how do I access the Hub 2 Hub Manager now it's all up and running as a bridge?
3 REPLIES 3
mnsuk
Re: Accessing Hub 2 Hub Manager whilst in bridge mode?
Well, that's embarrassing, I just answered it myself two minutes after posting. See: https://community.plus.net/t5/My-Router/Plusnet-Hub-2-bridge-mode-possible-to-get-line-stats/td-p/18...
Fixes: 587
@mnsuk I believe it will respond, on the IP address it was configured to before it was switched to bridge mode (default 192.168.1.254) , to a client connected directly to one of its LAN ports. However its DHCP server is disabled so you will need to set a static IP, in the routers subnet (default 192.168.1.x), on the client
edit: you found that quicker than I did😀
Hi, in the referenced thread I posted
I used a different approach.
For bridge mode you connect any LAN port of the Hub two to the WAN port of your router.
I then connected another LAN port of the Hub Two to a LAN port of the router.
I gave a PC a second IP address in the Hub Two network range.
For this to work the Hub Two and Routers network ranges must not be the same, in my case 192.168.1.0/24 and 192.168.10.0/24
I found this approach problematic with intermittent drops of the broadband connection for my LAN.
The PC I use is still connected to my home network with a seperate connection using a USB LAN adapter for the 192.168.1.0 /24 network.
HTH
