Edgerouter POE unable to connect to internet
ukbikenerd
I'm new to the forum, and to the world of routers.
I've tried to configure thig futer, but have no internet connection. I set router up using the WAN+2LAN2 wizard.
Looking at other posts, its notable that my pppoE IP address is 172.22.37.29/32. This suggests it is in the private range, and implies a username or password error, however both appear to be correct.
Downloading the config file, and comparing with others posted, its noticeable that section showing port forwarding, hairpin enable, wan-interface pppoe is missing, but I may just be misunderstanding the example config file.
The log file shows
I am not seeing any outbound or inbound traffic
All help gratefully received!
20 REPLIES 20
killsta
Re: Edgerouter POE unable to connect to internet
Can you post your config?
Here is mine for PPPOE authentication:
ethernet eth0 {
description "Internet (PPPoE)"
duplex auto
pppoe 0 {
default-route auto
firewall {
in {
name WAN_IN
local {
name WAN_LOCAL
mtu 1492
name-server auto
password ****************
user-id xxx@plusdsl.net
Oldjim
Fixes: 63
What actually are you trying to do and what are you connecting it to as this unit is neither an ADSL or FTTC capable router
killsta
These are enterprise routers, it will be connected to a DSL model Smiley (Hopefully!)
ukbikenerd
The Router is connected to a BT Openreach fibre broadband modem.
Oldjim
Fixes: 63
what format are you using for the username as it should be username@plusdsl.net with your normal account password
scrookes
Fixes: 4
Good Afternoon,
Can you PM me your Plusnet username please. If you're getting a 172.x.x.x IP address, this generally infers that the DSLAM has placed you in the walled garden due to repeated failed connection attempts.  With your username, I can access your account and check that for you.
ukbikenerd
My config;
ubnt@ubnt:~$ cat /config/config.boot
firewall {
    all-ping enable
    broadcast-ping disable
    ipv6-receive-redirects disable
    ipv6-src-route disable
    ip-src-route disable
    log-martians enable
    name WAN_IN {
        default-action drop
        description "WAN to internal"
        rule 10 {
            action accept
            description "Allow established/related"
            state {
                established enable
                related enable
        rule 20 {
            action drop
            description "Drop invalid state"
            state {
                invalid enable
    name WAN_LOCAL {
        default-action drop
        description "WAN to router"
        rule 10 {
            action accept
            state {
                established enable
                related enable
        rule 20 {
            action drop
            state {
                invalid enable
    options {
        mss-clamp {
            mss 1412
    send-redirects enable
    source-validation disable
    syn-cookies enable
interfaces {
    bridge br0 {
        address 192.168.1.1/24
        aging 300
        bridged-conntrack disable
        description "Local Bridge"
        hello-time 2
        max-age 20
        priority 32768
        promiscuous enable
        stp false
    ethernet eth0 {
        address dhcp
        duplex auto
        poe {
            output off
        pppoe 0 {
            default-route auto
            firewall {
                in {
                    name WAN_IN
                local {
                    name WAN_LOCAL
            mtu 1492
            name-server auto
            password NNNN
            user-id NNNN
        speed auto
    ethernet eth1 {
        bridge-group {
            bridge br0
        duplex auto
        poe {
            output off
        speed auto
    ethernet eth2 {
        duplex auto
        poe {
            output off
        speed auto
    ethernet eth3 {
        duplex auto
        poe {
            output off
        speed auto
    ethernet eth4 {
        duplex auto
        poe {
            output off
        speed auto
    loopback lo {
    switch switch0 {
        bridge-group {
            bridge br0
        mtu 1500
        switch-port {
            interface eth2 {
            interface eth3 {
            interface eth4 {
            vlan-aware disable
service {
    dhcp-server {
        disabled false
        hostfile-update disable
        shared-network-name LAN_BR {
            authoritative enable
            subnet 192.168.1.0/24 {
                default-router 192.168.1.1
                dns-server 192.168.1.1
                dns-server 208.67.222.222
                lease 86400
                start 192.168.1.38 {
                    stop 192.168.1.243
        use-dnsmasq disable
    dns {
        forwarding {
            cache-size 150
            listen-on br0
    gui {
        http-port 80
        https-port 443
        older-ciphers enable
    nat {
        rule 5010 {
            description "masquerade for WAN"
            outbound-interface pppoe0
            type masquerade
    ssh {
        port 22
        protocol-version v2
system {
    host-name ubnt
    login {
        user NNNN {
            authentication {
                encrypted-password NNNN
            level admin
    ntp {
        server 0.ubnt.pool.ntp.org {
        server 1.ubnt.pool.ntp.org {
        server 2.ubnt.pool.ntp.org {
        server 3.ubnt.pool.ntp.org {
    offload {
        hwnat disable
        ipv4 {
            forwarding enable
            pppoe enable
ukbikenerd
Ah,
I have username@plusnetdsl.net.
I'll try that
ukbikenerd
Progress. Thank-you. Changing the username gave me a more valid IP address for pppoE:
Which is consistent with the WAN IP address
But still no internet. Error message is DNS_PROBE_FINISHED_NO_INTERNET
Log is;;
killsta
If you've got a valid WAN IP now then that's progress. Looks like your config is somehow preventing access.
Try the following:-
configure
delete interfaces
Paste the following commands, ensure to replace your user/pass in lines 8 and 9.
set interfaces ethernet eth0 description 'Internet (PPPoE)'
set interfaces ethernet eth0 duplex auto
set interfaces ethernet eth0 pppoe 0 default-route auto
set interfaces ethernet eth0 pppoe 0 firewall in name WAN_IN
set interfaces ethernet eth0 pppoe 0 firewall local name WAN_LOCAL
set interfaces ethernet eth0 pppoe 0 mtu 1492
set interfaces ethernet eth0 pppoe 0 name-server auto
set interfaces ethernet eth0 pppoe 0 password xxxxxxxx
set interfaces ethernet eth0 pppoe 0 user-id nnnnnnnn
set interfaces ethernet eth0 speed auto
set interfaces ethernet eth1 description Local
set interfaces ethernet eth1 duplex auto
set interfaces ethernet eth1 speed auto
set interfaces ethernet eth2 description Local
set interfaces ethernet eth2 duplex auto
set interfaces ethernet eth2 speed auto
set interfaces ethernet eth3 description Local
set interfaces ethernet eth3 duplex auto
set interfaces ethernet eth3 speed auto
set interfaces ethernet eth4 description Local
set interfaces ethernet eth4 duplex auto
set interfaces ethernet eth4 poe output pthru
set interfaces ethernet eth4 speed auto
set interfaces loopback lo
set interfaces switch switch0 address 192.168.4.1/24
set interfaces switch switch0 description Local
set interfaces switch switch0 mtu 1500
set interfaces switch switch0 switch-port interface eth1
set interfaces switch switch0 switch-port interface eth2
set interfaces switch switch0 switch-port interface eth3
set interfaces switch switch0 switch-port interface eth4
set interfaces switch switch0 switch-port vlan-aware disable
commit
Then try pinging google from the router Smiley
ukbikenerd
Just to check before I do this - (plus I will have to learn how to download, modify and reload config file).
I have reviewed the code you suggested in the config tree.
I have a bridge br0, with address 192.168.1.1/24.
Your code doesn't appear to have a bridge - I am assuming this is replaced by the switch switch0.. I assume where your code has switch IP address 192.168.4.1/24 this reflects your individual needs, and I would need 192.168.1.1/24 - or am I incorrect? My bridge br0 has MTU 1500 and description local - as the proposed switch, but does not have any of the interfaces.
Is there a reason for doing a switch rather than a bridge? Would my bridge work if I added interfaces to it - assuming this is a sensible question?
All my other config code looks the same in the config tree
My brid
ukbikenerd
One other point I just noticed - my eth0 address is shown as DHCP, whereas the proposed code has no address shown - is this significant?
killsta
You are correct.
However my method was to get a simple, working configuration up and running (the one I posted is a basic PPPOE WAN on eth0 with eth1/eth2/eth3/eth0 configured as standard switching (switch0)).
Once it is working you can add your custom configuration to suit your needs, i.e. bridging, etc.
killsta
My eth0 doesn't show as address DHCP:
interfaces {
ethernet eth0 {
duplex auto
pppoe 0 {
default-route auto
firewall {
in {
name WAN_IN
local {
name WAN_LOCAL
mtu 1492
name-server auto
user-id xxxxxx@plusdsl.net
speed auto
ethernet eth1 {
description Local
duplex auto
speed auto
ethernet eth2 {
description Local
duplex auto
speed auto
ethernet eth3 {
description Local
duplex auto
speed auto
ethernet eth4 {
description Local
duplex auto
poe {
output pthru
speed auto
loopback lo {
switch switch0 {
description Local
mtu 1500
switch-port {
interface eth1 {
interface eth2 {
interface eth3 {
interface eth4 {
