Draytek 2860n settings help!
corringham
Seasoned Champion
Fixes: 23
Re: Draytek 2860n settings help!
Being optimistic, lets assume it is in fact VDSL (that's FTTC) - the required settings (from the Plusnet help page) are:
Broadband username or login name yourusername@plusdsl.net
Connection type or encapsulation PPPoE Always On
Password The password you use to log in to the Member Centre
VLAN Active
VLAN ID (802.1q) 101
VLAN ID (802.1p) 0
give that a go and see what happens...
Edit: just to be clear, the 101 should go into the VSDL tag value field
autocraft
Tried that, its still not working....
might have to sleep on it
Fixes: 585
Can you repost those last 2 screens now that you've changed the settings
autocraft
BINGO!!!!
id put the last setting into the wrong box.
Working now!!!
Thanks for all your help!
Martin
Mav
Fixes: 518
Moderator's note(s):
Thread moved from ADSL Broadband to My Router.
Forum Moderator and Customer
Fixes: 585
Glad we got there in the end.Smiley
I did wonder at the start of this, why someone would be using a 2860 on ADSL! It seemed a terribly expensive overkill.
corringham
Seasoned Champion
Fixes: 23
Well I use a 2860n+ on an ADSL line - it is a very competent router. Allows me to load-balance ADSL with 4G (using a Mikrotik SXT LTE Kit). Mind you I also use a number of fairly expensive Ubiquiti switches and access points, so I'm not a typical case.
autocraft
I used to use it at my workshop, so when i closed it down i wanted to use it at home as its a cracking bit of Kit.
I'll screen grab all the settings and post them up for anyone else who has the same problem.
BTW the wifi and connection drop out issue ive been having with the free plusnet router has now gone away Wink
Fixes: 585
Certainly is and if you already had it I can see why you would use it , even if you had ADSL!
Personally, I'd love one but can't justify the cost. Instead I've got a used 2830 (and a spare) which cost me the princely sum of £35 total. Originally I used it on ADSL but when I moved to FTTC I got a TPlink 9970 to use as a modem in front of it.
autocraft
Screen Grabs as promised.
Ive blanked out my username / password etc.
Hope it helps someone.
Thanks again its all working a treat Wink
