Disable WPS
rolya
Disable WPS
Does anyone have any knowledge of:
1) security risks of having WPS enabled
2) disabling WPS on BT whole home Wi-Fi
cheers
2 REPLIES 2
Fixes: 1,495
Re: Disable WPS
1) As the whole home / PN routers use a button (rather than an easily crackable pin ) someone requires physical access to your router / discs to activate it. You might have more pressing issues if that's the case.
2) it can be disabled in the set up tab on web admin http://mybtdevice.home/index.htm
rolya
Re: Disable WPS
Brilliant .. many thanks for the very useful insight and web address
