Disable WPS
FIXEDTopic Options
- My Router
- Re: Disable WPS
10-12-2021 10:40 PM
Does anyone have any knowledge of:
1) security risks of having WPS enabled
2) disabling WPS on BT whole home Wi-Fi
cheers
Fixed! Go to the fix.
Message 1 of 3
(2,501 Views)
2 REPLIES 2
11-12-2021 8:47 AM
1) As the whole home / PN routers use a button (rather than an easily crackable pin ) someone requires physical access to your router / discs to activate it. You might have more pressing issues if that's the case.
2) it can be disabled in the set up tab on web admin http://mybtdevice.home/index.htm
Re: Disable WPS
11-12-2021 9:43 PM
Brilliant .. many thanks for the very useful insight and web address
Message 3 of 3
(2,438 Views)
