DSN problem with Plusnet Hub One
r0nnyj0b
Hi, I moved to plusnet standard broadband (ADSL) 1 month ago and have been having to restart the plusnet hub one router at increasingly frequent intervals (several times a day). The hub one shows a constant blue bar with no flashing symbols, but I am unable to connect to any internet sites on wifi or LAN, on Windows, Android or Linux with windows diagnostics suggesting that there is no DNS server available. I can fix the problem on wifi and LAN on any device by manually setting DNS server to 212.159.6.10/9.
I have restarted each device - which does not fix the problem
I have restarted hub one which works for a while (few hours)
My phone line sounds fine and clear
I've removed the face plate from master BT Openreach phone socket (that is the only socket connected to the phone line) and plugged the broadband filter into the testing socket - problem still occurs
I have tried a different broadband filter - problem still occurs
I'm working on the assumption that the hub one is faulty
Any help greatly appreciated 🙂
4 REPLIES 4
Fixes: 1,495
Re: DSN problem with Plusnet Hub One
Moderators Note
This topic has been moved from ADSL Broadband to My Router
Fixes: 1,663
Hi @r0nnyj0b
I'm sorry to see you're having DNS issues with your new router. Based on the troubleshooting you've done, I agree that it looks like the Hub One's faulty so I've arranged to send you a replacement you should receive within 3 to 5 working days.
Let us know how it goes once you've got it.
r0nnyj0b
Hi Gandalf,
Many thanks for sending the replacement router. So far (24 hours) it has been working perfectly. I have removed the static DNS addresses and there have been no DNS issues. I will return the original router in the envelope provided.
Cheers,
Andy
Fixes: 1,663
Awesome, I'm glad to see your new router's working a lot better. Thanks for the confirmation Andy.
No problem, let me know if there's anything else you'd need help with. Smiley
