DNS drop out
dallday
Re: DNS drop out
checked the log of the checkdns script and these are the error lines, just spotted a small error in the code - it is not checking 212.159.6.10, but 212.159.6.9 twice. Now correct the error and will keep monitoring.
2022-02-13-13-18-01 error my router local dns
2022-02-13-13-19-01 error my router local dns
2022-02-13-13-20-01 error local dns
2022-02-13-13-21-01 error my router local dns
2022-02-18-14-01-01 error 212.159.6.9
2022-02-20-19-14-01 error my router local dns
2022-02-20-19-15-01 error my router local dns
2022-02-22- 0-09-01 error 212.159.6.9 212.159.6.10
2022-02-26- 8-04-02 error local dns
2022-02-26- 8-05-01 error my router local dns
2022-02-26-17-03-01 error local dns
2022-02-26-17-04-01 error my router local dns
2022-02-26-17-05-01 error my router local dns
2022-02-26-17-06-01 error my router local dns
used
grep 'error' checkdns.txt
to list out just the error times
Setup a new check process on a Pi connected directly to the router, so far no errors Smiley
David
bobpullen
Fixes: 331
Re: DNS drop out
Thanks David, let me know how it goes.
Those latest results don't look as conclusive so it would definitely be helpful to rule out the Wi-Fi element.
Just to clarify: DHCP is disabled on all additional access points, yes?
bobpullen
Fixes: 331
Re: DNS drop out
How have things been recently @dallday?
bobpullen
Fixes: 331
Re: DNS drop out
@dallday - FYI, we're probably going to close the investigation at this side unless there's any progress to share?
Let me know if things are still in a state where we can do some more digging.
