Connectivity issue
- My Router
- Re: Connectivity issue
Connectivity issue
21-12-2024 11:16 AM
Hi so since I came across from BT to plusnet.
I have had issues whilst connected to the WiFi
The issues are not being able to receive email and not being able to use google voice both the issues don’t happen if I turn the WiFi off. I’m using a I phone 14pro max with the latest apple software.
All other devices that are connected other phones tv etc are all connected to the WiFi and it works fine.
I have turned this phone off and the router so many times now but still the both issues are still the same.
I can get all other internet on my phone whilst connected to WiFi
Any help would be kindly appreciated many thanks Chris
Message 1 of 3
(877 Views)
2 REPLIES 2
21-12-2024 12:02 PM
Moderator's note:
Thread moved from Full Fibre to My Router
Message 2 of 3
(850 Views)
21-12-2024 1:03 PM - edited 21-12-2024 1:04 PM
That sounds as though the phone is not connecting to the WiFi properly. When you switch the WiFi off, the phone then connects via mobile data and all is fine.
Tell the phone to forget your WiFi network and then reconnect it.
Message 3 of 3
(829 Views)
