Connecting another Plusnet #2 router to the main one to improve wifi coverage
Marcus_Simpson
Hi Everyone,
I have 2 plusnet 2 routers.  I'd like to connect the second to the first via ethernet to improve the wifi coverage to run a security camera attached to the side of my garage.
I can follow basic instructions and can access the advanced menu in either router.  The guidance from other posts does not quite match the routers I have hence this post.
Thank you,
Marcus Simpson.
4 REPLIES 4
Re: Connecting another Plusnet #2 router to the main one to improve wifi coverage
@Marcus_Simpson
welcome to the community
Try this link Hub two as WiFi access point
Edit: you would connect LAN to LAN port.
Marcus_Simpson
Hello Dan,
Thank you for linking a previous post to my query.  If for example I want to have the second router mimicking the first to roam across routers can I change the router name and password to be the same as for the master router?  If so how do I do that?
I assume that in the case this all doesn't work then providing that nothing has changed on the master router a factory reset will return the second router back to its previous adjusted state?
Thanks,
Marcus.
To change the WiFi name and password to match the main router, look here
A factory reset does the trick.
Marcus_Simpson
Thanks Dan.  I'll give this a go and see how I get on.
