Configuring talk talk router to work on plusnet internet
alexemmaburns
Hi I just wondered if anyone knew  if there was any way of configuring talk talk's router 'Huawei HG533' on my PN internet rather than using the plusnet supplied 2704n? I find the PN router not very good for gaming and would like to try and see if my talk talk one works any better?
15 REPLIES 15
Mustrum
Fixes: 81
Re: Configuring talk talk router to work on plusnet internet
The question has been asked before, have a read here, but make sure you read it all, as there is some duff info in there.
alexemmaburns
Thankyou @Mustrum I will give that a go shortly.
Anotherone
Champion
Fixes: 21
The information in message #3 is correct. I've been trying to look for where you'd put in your PN Username and password.
Set it up Off-line and make sure all the settings are correct before trying it. The way to do this is leave your 2704n connected to the line, just unplug your computer ethernet from it.
Power up the HG533, connect your computer to it, reboot the computer to pick up the HG522 DHCP etc and log into it.
When you've finished changing settings and saved them, reboot the HG533 to check they have all been save correctly.
If all is well, power off the 2704n, wait about a minute beofre unplugging from the line. Wait about 5 minutes before connecting the HG533 (so that DLM hopefully doesn't look at your disconnect as a dropped connection). HTH.
alexemmaburns
Thankyou @Anotherone I am going to do this tomorrow during the day when I'm home I thought best to try a different router see if it works for me, hopefully it will make a difference.  I shall update to you once I have finished and let you know if this has helped me at all Smiley
Anotherone
Champion
Fixes: 21
No problem. I'll reply to your other thread about your connection and ticket a little later. What's irritating me is I know there is another post about the HG533 somewhere but be blowed if I can find it atm.
alexemmaburns
That's  okay not a problem I just thought I'd ask here as I know people have come over from talk talk so hoped someone may have used the router with plusnet settings Smiley I take it my username and password for plusner will be what is on the card that came with my 2704n router?
Anotherone
Champion
Fixes: 21
What's on the plastic card that came with the 2704n is the login details for the 2704n and the wireless id and password/phrase.
You Plusnet broadband username for the broadband will be of the format  username@plusdsl.net  and the password is the same one you use to log into the member centre / portal and also your plusnet email.
Mustrum
Fixes: 81
Beat me too it, what #Anotherone saidWink
alexemmaburns
Ah right I get that now thank you.  Will I need a laptop to do all this or should I be able to do it wirelessly?
Anotherone
Champion
Fixes: 21
I'd recommend you use a laptop. Configuring modem/routers via wireless is generally a bad idea.
Mustrum
Fixes: 81
Beat me again, laptop via wired usually means less problems.
Anotherone
Champion
Fixes: 21
I'll leave the next one to you Wink time for food Smiley
alexemmaburns
Not a problem I'll do it on a laptop tomorrow I only really have this tablet, I have a laptop but the processor is bust so it switches itself off should be able to keep it on long enough though.  I'll let you know how it goes thanks to both of you for your reply's Smiley
Anotherone
Champion
Fixes: 21
Did you have a go at configuring it?
