Change router
Brian15
Change router
Can I change my router from Hub One to Hub Two and will that help with wifi access in the house?
2 REPLIES 2
markhawkin
Champion
Fixes: 22
Re: Change router
If you recontract you will probably get the chance of having a Hub 2 for the postage charge (and possibly a discount on your current payment) but it depends on whether you are eligible to recontract.
The general consensus is that the Hub 2 WiFi is better but a more reliable way of improving WiFi is to get a mesh system and plug it in to your Hub 1 (and turn off the Hub 1 WiFi).
I don't have a personal recommendation but the BT Whole Home Wi-Fi seems to get generally good reviews on Amazon so if I were in the market I might consider that.
Brian15
Re: Change router
Thanks for this advice.  I may be able to recontract so I might try that first
