Can't connect to work VPN with my Plusnet Hub 2 Router
Marmat
I am trying to work from home, and I used to be able to connect my work VPN when I set the firewall settings low. However, it stopped connecting, even when I switch the firewall off.   I'm a little stuck, any suggestion would be appreciated.
3 REPLIES 3
corringham
Seasoned Champion
Fixes: 23
Re: Can't connect to work VPN with my Plusnet Hub 2 Router
There are a lot of possible reasons a VPN won't work. You really need to see a log message that reports the connection problem to be able to fully diagnose the issue. Does your VPN client produce log files? If not can they be enabled? Can you ask your work IT dept to check logs at their end?
One possible reason for a previously working connection to fail is if your IP address has changed, and is now in a prohibited range (possible because it used to be registered overseas) - so has your IP address changed? If you look your IP address up on a whats my IP website does it report its location as being overseas?
Marmat
Thanks, I have looked up my IP address, it points to the UK. I will try again with work IT to check logs.
Champnet
Fixes: 21
 If your IP address has changed it's worth checking with your work's IT dept to see if the old IP address is configured on their system, if so, it will need changing.
