Can I throw my old Plusnet Hub One Router away or do Plusnet need them back (for recycling)?
FIXED- Subscribe to RSS Feed
- My Router
- Re: Can I throw my old Plusnet Hub One Router away...
3 weeks ago - last edited 3 weeks ago
I had my Plusnet Hub Two hub in May 2023 and the Hub One has been sitting in a box unused since then.
I know that Plusnet owns these hubs and the Hub One is end-of-life so do I take it to a tip or must I return it to them? If so how do I do this?
Thanks.
Fixed! Go to the fix.
Re: Can I throw my old Plusnet Hub One Router away or do Plusnet need them back (for recycling)?
3 weeks ago
3 weeks ago
Thank you. I looked into the link and it seems Plusnet have not asked me to return it because I signed up before 1st Feb 2024 (photo).
Just as well because I have the Plusnet Hub Two box and thought the Hub One was inside it but it isn't. The box is empty. I must have got rid of the Hub One and forgotten but at least I have the box for returning the Hub Two if needed.
Thanks for the link. I can call this fixed now.
- My Router
