Can I clear the device list?
MisterPlusBoy
http://192.168.1.254/my_network.htm shows loads of disconnected devices no longer in use. I think I saw an option to remove individual devices but is there a way to bulk clear the list, or at least disconnected devices (other than a factory reset)?
1 REPLY 1
Re: Can I clear the device list?
With either the Hub One or Two it is not possible to bulk delete devices.
For the Hub two go into Advanced Settings >My Network >My Devices (you will be prompted for the admin password)
Select remove for the required device, the page should refresh and show the device has gone.
HTH
