Port Forwardin for Tinycam
Slarti997
Tinycam says I should forward onvif (2020) and RTSP (554) ports  to access my cameras remotely but  I'm not sure what the rule in the hub 2 should look like. At least I can't get it to work.
Help ! Thanks
Moderators Note: All caps title removed as per Forum rules
8 REPLIES 8
Fixes: 1,495
Re: Port Forwardin for Tinycam
I'd have thought it should look something like:
device should obviously be the tinycam
Slarti997
Many thanks. But how do I get the second row of ports up. I seem only to be able to create a new rule. How to add the next line of ports ? TaHow to add the next line of ports ? Ta
Fixes: 585
When you are creating a new rule the 'x' sign should change to a '+' allowing you to add more lines of ports
https://www.bt.com/help/broadband/learn-about-broadband/how-do-i-set-up-port-forwarding-on-my-bt-hub...
Slarti997
Thanks got this but still no joy accessing externally.Screenshot_20230620_123048_Chrome.jpg
Fixes: 585
How are you trying to access it externally ? do you have a static IP or are you using DDNS ?
Slarti997
Sorry I've dragged you down the rabbit hole with me. I'll cough up for a static ip and try again. Thank you for your time and help..
Fixes: 585
There's no online way of getting a static IP these days. You need to either wait for a staff member OR try calling customer services and hoping to get someone who knows about static IPs.
Might be simpler and quicker to create a free NOIP account https://www.noip.com/ and configure the Hub 2 DDNS.
Slarti997
Ah OK. I think I may be back to haunt you. I'll mark this as solved since the  specific question is done. Thanks
