CCTV not connecting to hub2 router
nicanddes
Just upgraded from hub1 to hub 2 router and my Ezviz cctv WiFi cameras won't connect. Went back to hub1 and all fine. Cameras have been reset to wipe previous settings but still no joy on hub2. Cameras are 2.4GHz so I even disabled the 5GHz band of the hub2 to eliminate that but they just don't see the router. Have had to go back to the hub1 for now. Any ideas?
7 REPLIES 7
Fixes: 250
Re: CCTV not connecting to hub2 router
Does this help - How to solve Wi-Fi configure failed issue? - FAQ - EZVIZ Support (ezvizlife.com)
Fixes: 479
Moderators Note
This topic has been moved from ADSL Broadband
nicanddes
Unfortunately not, tried this already
Did you try making the Hub Two Wireless network name (SSID) the same as the Hub One?
Within the settings of the Hub Two wireless network is the ability to change the mode, the default being one.
It might work, worth a try
Dan
Gel
Champion
Fixes: 29
Thanks for the warning about the password, currently the Hub Two is operating in 'Bridge Mode' so Wireless is turned off.
Dan.
nicanddes
This did the trick. Setting router to mode 3 enabled the cctv to pick it up, then upped it back to mode 1 and they remained connected. Thanks
