Buffalo router
- My Router
- Buffalo router
Buffalo router
12-12-2020 4:07 PM
I am on Plusnet Fiber and have the supplied Openreach box and a Sagemcom router. I am finding the Plusnet supplied router is now a bit 'flaky' and not reaching to all parts of our house. I have a Buffalo Airstation WBMR - HP - G300H modem/router from a previous ISP setup. Problem is that when I connect to the Openreach Fiber box it throws up an error that it's not connected to the internet. This happens whether I use a wireless connection or a hard connection. Does this mean I can't use the Buffalo unit at all or am I just being thick?
Re: Buffalo router
12-12-2020 4:22 PM
This topic has been moved from from Fibre Broadband to My Router.
Re: Buffalo router
12-12-2020 4:28 PM
From what I can see, the Buffalo Airstation G300H does not have a WAN ethernet port and therefore can't be used in conjunction with the BT modem. It's internal modem is only ADSL compatible and therefore it cant be connected directly to the phone line either.
Re: Buffalo router
12-12-2020 4:37 PM
Hi MisterW, that's what I thought but good to have it confirmed. I'm very much a dimwit when it comes to connecting to the internet! Bought the Airstation some years ago so can now probably throw it out and look for something else; it's only money after all...
Re: Buffalo router
12-12-2020 5:02 PM
There's one on eBay for £30 plus :
Re: Buffalo router
12-12-2020 6:56 PM
From looking around this forum, people seem to be suggesting that a BT Hub 6 is a good solution to my existing two box setup. How much of a difference is there between the BT Home Hub 6 and its Business equivalent?
Re: Buffalo router
14-12-2020 4:34 PM
There are more setting options on the Business versions. For example you can set your own choice of global DNS servers, rather than be forced to use the Plusnet ones.
Re: Buffalo router
16-12-2020 3:29 PM
Thanks Baldrick1, I've bought a BT Hub 6 from ebay, now I just need to set it up which according to the instructions with it seems quite easy - my experience of life tells me that this might not be the case!😣
Re: Buffalo router
17-12-2020 4:05 PM
Do the instructions look like this? https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/m-p/1587673#M85...
Be aware tht some versions of firmware do not like special characters in the Plusnet password so if you have problems connecting then change your password to alpha numeric ones. Ignore any comments regarding using a special one. Also make sure that the DSL cable is disconnected whilst you enter your Plusnet credentials. Let us know if you have problems.
Re: Buffalo router
18-12-2020 4:50 PM
Hi Baldrick1, excellent instructions, I found them on another thread and printed them out. Needless to say you are a star! I followed them carefully and I've now got this wonderful blue light from the SmartHub 6.😀
Thanks again and have a great Christmas, or as great as you can have under the present circumstances. Graham
