unifi usg to hub 2 bridge mode
martin1959
hi i’m trying to connect with the hub2 as a modem and the unifi usg doing the pppoe as my firewall. not having much luck : (
Previously we were using a draytek  vigor  166 vdsl modem which gave up the ghost so i was hoping to use the hub 2 as a bridge which i have set in the hub2. Am i missing something …. do i need to add the vlan  id 101 to the firewall or is that something the hub2 handles. Hope somebody has tried this and can point me in the right direction.
cheers
Tags (3)
1 REPLY 1
Fixes: 581
Re: unifi usg to hub 2 bridge mode
No, the Hub 2 will handle the VLAN Id. Ensure that its disabled in the USG.
When in bridge(modem) mode the Hub2 LED should be pink.
