Basic security principles
greygit
Disable any services or protocols that you don't (currently) use.
When will I be able to disable SIP on the Hub2?
3 REPLIES 3
bobpullen
Fixes: 331
Re: Basic security principles
In what way exactly? The SIP ALG can be disabled and the embedded client is not configured to do anything.
greygit
The log says 'SIP enabled'. (It is disabled on boot, then gets enabled)
There's no option to disable on the web interface.
bobpullen
Fixes: 331
I can assure you, whether the client is running as a process or not, it is definitely not registering to a SIP server.
