BT Smarthub 6 Business & VPN
Empire
I  bought a VPN for a year, just curious no particular need for it.    set up on two machines  Windows 10 pro  &  Windows 11  Pro   works as it should,
no noticable lag today. may slow down around   5pm- 8
PIA techsite says you can run a VPN on your router UDP  but because Routers generally have low CPU + RAM equiv to an older Windows 98 PC Router   so your router will have reduced performance approx 10%   etc etc
Any ideas, is anyone using a VPN on the router instead on the PC Windows VPN APP they have?
regards
E
2 REPLIES 2
Fixes: 480
Re: BT Smarthub 6 Business & VPN
@Empire
I'm 99% sure that you can't install a VPN on a Business Smarthub, which makes the question irrelevant.
VPNs work by sending the connection 'around the houses' and will always have some effect on performance.
Empire
thanks B, i see after diging around you cant, you can only change Port to 500, via Port Clamping, it appears this aids/helps VPN  service which are on your PC/Latptop wherever.
re VPN speedtest now 7.00PM   peak period ( i guess )  on Boris's Beer & Chips  Island  its down a little,  marginally not noticable unless you measure.
I sent a message to my VPN Co. asking whether or not it worth having Cloud Flare 1.1.1.1   as setting on wireless & ethernet adaptors. awaiting reply.
