2704N router stopped working
jonahf
My router stopped working last night. Power and WPS lights are solid green. All other lights are out.
Router address does not respond. (timeout)
Phone line works.
I tried holding in the reset button but this had no effect.
I could successfully connect my old EE brightbox router and it connected but I suspect I was soon thrown off, as no longer being an EE broadband customer. This suggests to me the line is ok.
Browsing the forum, it seems my router is basic, old and unreliable. It appears the advice is to upgrade to a newer PlusNet router or buy a 2nd hand BT Smarthub.
Service seemed to degrade after I took out a new 18 month contract arount May.
I was away from July to October, but it worked ok on return for last 2 days. Now nothing.
Any further advice appreciated.
Jon
6 REPLIES 6
Fixes: 1,495
Re: 2704N router stopped working
Moderators Note
This topic has been moved from ADSL Broadband to My Router
jonahf
Thanks for the reply dvorak.
Tantalising (in the email) I can see "There's something going on in" but no more.
I may be looking in the wrong place.
Jon
Fixes: 1,665
Thanks for your post @jonahf and welcome to our Community Forums.
I'm sorry to see your router's stopped working.
Based on what you've said and line tests aren't showing an issue, I've arranged to send you a newer router now which you should receive this week.
Let us know how it goes once you've got it. Smiley
jonahf
New router arrived and all working fine.
Many thanks for the prompt arrival.
Jon
Mav
Fixes: 518
Moderator's note by Mike (Mav): The fix has been changed to @Gandalf as per message #4.
Forum Moderator and Customer
BD
Fixes: 86
Hi @jonahf, thanks got getting back to us and it's great to heart he new router looks to have resolved the issues you were seeing. If there's anything we can help you with moving forwards then please don't hesitate getting back in touch.
