BT Smart Hub 6-Recommendation
- My Router
- BT Smart Hub 6-Recommendation
09-06-2018 8:22 AM
Hi
For a year or more I had WiFi issues, particularly on iPhone's where the signal dropped off. I had changed channels, had a new router, reset the router, phoned the technical helpline several times etc.
After seeing an advert for BT saying the UK's strongest WiFi, I bought the Smart Hub 6 (£15 off Facebook), what a difference it makes, any video plays all over the house and scrolling on any social media app works flawlessly.
I hope this helps some one else.
1 REPLY 1
Re: BT Smart Hub 6-Recommendation
10-06-2018 3:48 PM
Moderator's note:
Topic moved from Fibre broadband to My Router.
Message 2 of 2
(754 Views)
- My Router
