BT Smart Hub 2 firmware update
Fixes: 480
Re: BT Smart Hub 2 firmware update
@trippy wrote:
I got it from my father in law, brand new never used. It did do a fw update the first time i powered it up, but never since then. I was wondering if something was corrupted in the internal memory based on the weird characters in the error message of the last log.
But i've reset the router multiple times, by the reset button and from the web control panel and the error is always there at the midnight update.
If there is any ideas on what the error number signifies and how to correct it that would be useful.
Could you persuade your father in law to use it for a few days? It’s probably a long shot but there’s a chance that when it does its daily check in when connected to his BT account that it will kick off the update. You would obviously need to factory reset before he uses it.
trippy
I had that thought as well!
when they aren’t shielding I’ll give it a go.
