Asus ZenWiFi XD6 with Full Fibre 900Mb?
RS00
Hello everyone
Do you think I could attach my existing Asus ZenWiFi XD6 to the new ONT, if I upgrade to Full Fibre 900? Will PN mind? And will it still work? Only it works really well with our current broadband setup, particularly as it has an extra node thingy, and I don't know if the supplied Hub 2 will be as good?
Thanks!
6 REPLIES 6
Fixes: 378
Re: Asus ZenWiFi XD6 with Full Fibre 900Mb?
@RS00 You can use any compatible router with PN - they don't mind at all.
Fixes: 145
@RS00
Who are you currently with?
plusnet use PPPoE for upstream connections, you will need to configure the using these setting
Broadband username or login name - [email protected]
Connection type or encapsulation - PPPoE
Password - The password you use for the members centre.
There is NO requirement for a VLAN as the ONT provides this.
WAN port of the Asus to ONT
RS00
That's good to know, thank you! 😃
RS00
Thank you, yes I'm already with Plusnet, so this would be an upgrade. This is really useful info, thank you very much. 😃
Fixes: 577
@RS00 just be careful if you've got any QoS settings enabled  on the XD6. A lot of processing power is needed to use QoS at gigabit speeds, so you MAY find it needs to be disabled to get the full 900Mb speeds.
RS00
Ah, thanks for the tip. Cheers!
