Is there any demand for old routers or should I chuck them away ?
shermans
Living in an old house of three former cottages in a row, divided by three foot thick chalk walls plus my office above the garage on the other side of the courtyard, WiFi connection was problematic !  Many years ago, I solved the problem of internet access throughout the house by piggy-backing eight BT routers, stationed suitably around the cottages and in the lofts.
The system worked well until anno domini set in, and I started having to replace them.  Eventually, I looked around the market and found a much better alternative - a 'Deco 'system which just has four inter-linked wired stations which is fantastic - full flood wi-fi throughout.  I should add four is overkill and  I could have got away with three, possibly even two.  But never mind, the wires were already in place and just needed connecting.
That now leaves me with half a dozen old routers.  Question:  Are these old routers likely to be of any use to anyone these days?  I am loathe just to throw them away if there might be a use for them by someone else.
I would not want anything for them if I could find a home for them but I have no idea whether it would even be worth advertising them on something like eBay.
Any comments would be welcome.
5 REPLIES 5
Fixes: 382
Re: Is there any demand for old routers or should I chuck them away ?
How old are these items, and are they Fibre FTTC/FTTP compatible?  If not, I would suggest you dispose of them, following WEE disposal regulations.
paul_blitz
Fixes: 4
You could try and put them onto Freecycle (freesysle.org), you never know, someone out there might need an access point. I have a load currently listed on freecycle, only had one taken so far!
spile
They make useful network and wireless extenders. Many folk replace their router to improve WiFi performance when adding a repurposed router as a wireless point could be a better and certainly more cost effective option.
Fixes: 476
They may be useful as wireless access points if you can't afford a mesh set up, but as an Ethernet switch? If you compare the electricity consumed by a combined modem/router with that of an Ethernet switch, you will find that you will recover the purchase price of the switch in less than a year.
spile
I use my old router as a wireless point and make use of the network points. The Plusnet 2 router consumes around 5w more than a typical unmanned switch, costing around £8 to £10 a year to run.
