Asus RT-AC51u
warrenhull
Asus RT-AC51u
Hello Everyone
If I connect the above router (Asus RT-ac51u) behind a Plusnet one hub, via an Ethernet cable, could I run a VPN on everything connected to the asus ?
I realise that I would have to alter Wi-Fi channels , and frequencies.
Also I may come across double natting, and other network problems.
But in principle is it possible, to run a VPN enabled router through the Plusnet Hub one ?
Would this still work with a VPN provider ?I
My other concern is PPOE from the Plusnet one, can I send an open VPN signal to the Plusnet Hub one, and it go through to the VPN  provider ?
Any answers much appreciated.
