Am I being hacked? What is this?
doas
Have a look at the attached and see what you can tell me. There has been some issues with a mysterious bridge tap fault that is intermittent, and then the router stopped connecting to the web.  Still trying to sort it.
Tags (1)
8 REPLIES 8
Fixes: 387
Re: Am I being hacked? What is this?
@doas No, you are not being hacked. It looks like you are using a BT Hub, rather than Plusnet one, and for some reason its security certificate is out of date.
pvmb
Champion
Fixes: 15
@doas
If what you are wanting to do is log into the router, you should be OK. I think you can ignore all those dire warnings and go ahead, as you are simply logging in to the router in your own home. I don't know why the router's certificate is out of date. Possibly, as it is no longer being used on the BT Internet service, it is no longer registered with them for updates?
Fixes: 582
@jab1 a possibility ! but its more likely that its a Plusnet Hub 2 which has recently updated and is now forcing https:
The certificate is a 'self-signed' one and, since the Hub2 is based on the BT hub , explains the certificate name.
@doas just select the 'proceed' and set an exception to allow future access
see https://community.plus.net/t5/My-Router/Plusnet-Hub-2-new-firmware-forcing-https/m-p/2048138#M44610
Fixes: 387
Thanks,  @MisterW  hadn't thought of that, and as no longer use any BT Group kit, i'm slightly out of the loop.
doas
No it is the Plusnet router hub 2 supplied. Not a BT one.
pvmb
Champion
Fixes: 15
@doas
"No it is the Plusnet router hub 2 supplied. Not a BT one."
Then it's just the recent software upgrade to the Hub 2. Now requires https to connect plus login. It's not a problem (comments about this elsewhere in the forum) just bang on through, you are not connecting to anything outside your home network. But you will have to log in - using the Admin password - for anything on the Hub 2, from now on.
PhilipHeyes
Champion
Fixes: 20
Using HTTPS was supposed to improve security of credentials, but to home internet users the browser warnings are very  unexpected and look like a security failure has occurred.  Plusnet are not alone in this self-signed certificate kludge, VM have added it to their latest Hubs and the same negative reaction occurred from customers. I just hope we are not going to see this on all other types of home kit like network printers and VoIP gear, it will generate endless support calls.
Fixes: 250
@PhilipHeyes
That is very likely going to be the consequence of bodies who do not know what they are mandating making draconian changes in the “security” space.
This is yet another “security” solution seeking a real problem to fix.
