Admin passwords
Drummer22
Admin passwords
Afternoon all first time posting so forgive me if I'm in the wrong place.
I somehow managed to change the admin password on my home hub 6, and I cannot remember what I changed it to. Yes i know you don't have to tell me what I am. But I would appreciate it if you could help me change it back.
Many thanks in advance.
5 REPLIES 5
Fixes: 480
Re: Admin passwords
@Drummer22  Welcome to the Community forum
’Let he who is without sin cast the first stone’.
Simply factory reset with a paperclip in the reset hole keeping the switch closed for about 25 seconds. You will need to set it up again from scratch, see the instructions pinned to the top or this router board.
Moderators Note
This topic has been moved from Tech Help to My Router
Drummer22
Re: Admin passwords
Thank you for that I'll give it a try pray for me I may be gone some time lol
Drummer22
Re: Admin passwords
Hi baldrick1
Well I made it back which means it worked. Thanks so much for your help. I only wanted to check why the broadband speed was dropping and since the reset I'm getting nearly double speed so once again thanks for your help.
Fixes: 388
Re: Admin passwords
@Drummer22 As an aside, if your speed is dropping, that could indicate a network issue, which the 'reset' will have temporarily cleared.  Keep you eye on it, and post back, as a new topic in the 'broadband' board if it misbehaves again.
Drummer22
Re: Admin passwords
Thanks for that I'll keep an eye on it and send another post if it happens again cheers
