Amazon Echo Show 8
Peterlapin
Amazon Echo Show 8
Just moved and activated this week. Everything's fine. Echo Show 8 has found the WiFi but doesn't have voice activation. (The orange band). It's the Plusnet Hub 2.
Is this same same 2.5/5Hz situation as with the Hub 1, please?
5 REPLIES 5
Fixes: 480
Re: Amazon Echo Show 8
Moderators Note
This topic has been moved from Full Fibre to My Router
Fixes: 387
@Peterlapin I doubt it is the '2.4gHz' issue.
Does anything on this reply help? https://www.amazonforum.com/s/question/0D54P00006zSwZ9SAK/echo-show-2nd-gen-no-sound
Fixes: 480
@Peterlapin  Welcome to the Community forums
What orange band? Are you referring the Amazon device or the hub?
What 2.4/5GHz situation?
More details would be helpful.
Fixes: 387
Agreed, @Baldrick1 . Not an easy question to answer, but if I have a problem with a specific piece of electronic equipment, I find a quick online search saves me asking questions - hence my reply.
Browni
Aspiring Hero
Fixes: 61
The orange band on an Echo Show device indicates no internet connection.
@Peterlapin have you tried updating the WiFi settings as detailed here?
