Admin password blocked turning on WiFi
sheilajlister
Re: Admin password blocked turning on WiFi
Sorry - the browser i am using is Firefox
sheilajlister
I have solved the problem - with the help of one of the above answers telling me where to find the Admin password for Hub Manager!  I had been using the password 'Forgotten Hub Manager Password' gave me.
Fixes: 583
@sheilajlister
Normally I have WiFi disabled in the Hub 2 manager on my laptop, because, as I explained, I prefer using a LAN cable. (So not disabled in the Router.)
if you are disabling Wifi using the Hub manager, then you are disabling it in the router
