Configuring a Draytex Vigor 2865
stephen1812
Good morning, I have just signed up for PlusNet FF.  I want to use my own router which is a Draytek Vigor 2865Vac and checked the configuration guides which are generic.  I was wondering if anyone is using a Draytek router and if so do you have screenshots of relevant setup pages?   Thanks in advance for any and all help.
Also is there a compatibility list for devices that work on PlusNet Full Fibre?
Tags (2)
4 REPLIES 4
Fixes: 1,495
Re: Configuring a Draytex Vigor 2865
Moderators Note
This topic has been moved from Full Fibre to My Router.
Fixes: 585
@stephen1812
Basically any router with an ethernet WAN interface that supports PPPoE will work
markhawkin
Champion
Fixes: 22
I use a Draytek 2927.
Follow this guide (for BT but largely similar for Plusnet)
https://www.draytek.co.uk/support/guides/kb-fttp-wan-setup
Key things to know:
  • Username is as you sign in to the member centre with @plusdsl.net at the end.
  • Password is as you sign in to the member centre
  • There are no VLAN tags needed (the ONT effectively does this)
It does work, I'm using it now!
markhawkin
Champion
Fixes: 22
One other thought.
Once you have the 2865 working, if you have one of the faster full fibre packages you may find you don't quite achieve full speed.
If so, have a read of this
https://www.draytek.co.uk/support/guides/kb-hardware-acceleration-tips
