Adding static route to Hub Two
TrevHayz
Hi, anyone know if it’s possible to a add static route to a hub two ? I have a separate internal network separated from my LAN that’s connected to the HUB two by another gateway. But can’t find anyway to add this other network to the Hub Two, this is meant to be a business level router and can’t seem to do this basic function
4 REPLIES 4
bobpullen
Fixes: 330
Re: Adding static route to Hub Two
It's not possible I'm afraid. The Hub Two doesn't have the functionality.
TrevHayz
Thanks,  had to bin the plusnet hub because of this limitation
bobpullen
Fixes: 330
Bin it!? You could have sent it back to us Wink
TrevHayz
metaphorically binned, I will recycle it somehow either back to you guys, or just use as an unmanaged 4 port switch in a lab or something
