Add drive to Hub One
paulscarbs
Re: Add drive to Hub One
Cheers Baldrick1.
The current version is 4.7.5.1.83.8.263 so strange it does't identify anything useful.
As I mentioned in a previous post, it recognises a small USB but there's no way of accessing anything on it.
Fixes: 480
Looking back through the posts it appears that at that time the Hub One was on SMB v1. What we need is expert input from the likes of @bobpullen
bobpullen
Fixes: 331
This is still the case. You'd need to enable SMBv1 within Windows to be able to access the drive over the network. Not something I'd personally recommend when there are other shared storage solutions available.
paulscarbs
Thanks Bob,
I had enabled SMBv1 but it made no difference.
I have since connected a smaller 500gb hard drive and it is recognised!
I would suggest there is a limit on the size of drive and/or the format of the drive too. Any tips?
I am aware of alternative methods of storing data but, given I already have an 8TB HDD, I wanted to utilise that throughout the home. Would I be able to do this?
paulscarbs
Interestingly, I can only access the drive from within my MacBook (it was a HDD used on Windows!)
I have no write access from iOS but have no visible access from Windows!
markhawkin
Champion
Fixes: 22
I wonder if your big drive is formatted NTFS.
OS X can read NTFS but not write..
http://osxdaily.com/2013/10/02/enable-ntfs-write-support-mac-os-x/
What happens when you plug in the drive to the MacBook ?
paulscarbs
Yes, the smaller 500gb drive can be read on the MacBook. Perhaps it is NTFS (not a problem to change to ExFAT if I need).
This still leaves the question about why Windows can't even see the drive?
SilverE
Just out of interest, does anyone have the definitive answer to this? I've just (optimistically) tried connecting a 5TB NTFS GPT disk, with SMB1 enabled on my PC. The nice new Hub reports that a device is present but the "file type" is not supported.
@bobpullen only specifies that SMB1 is required - I have had always that active as my WDTVLive is an SMB1 server, so it's not just that. @markhawkin says the disk must be FAT32 - quite possible if the Hub is antediluvian, is PlusNet really putting out pre-XP devices that are 15 years out of date?? As that has a 4GB file size limit, large videos won't work on it. I'd be a bit less surprised if it's limited to 4TB, even the WDTVLIve (yes, made by WD) can't take more than that. And alongside that it probably needs to be MBR, not GPT.
I'm disappointed my drive doesn't work, though not too surprised. For anyone else trying, it sounds as if you'll probably not succeed unless it's a sub-4TB, FAT32, MBR disk with SMB1 enabled on your PC.
markhawkin
Champion
Fixes: 22
@SilverE l don't have the definitive answer but I strongly suspect that the disk support for Plusnet is more of an unintended function that came with original BT firmware than a required feature.
Even on my Draytek the USB disk function is extremely hit and miss. With the ever larger flash memory based USB drives obviously it would be nice to have a "free" facility for storage with a router but unless a current BT router supports this better I can't see a future Plusnet router being any better.
The average consumer seems to be moving to cloud storage for backup rather than something at home.
For many, rather than storage, turning a cheap USB printer into an Airprint capable device might be more useful.
Browni
Aspiring Hero
Fixes: 61
Here's a screen shot from the help available in the Hub 1, should answer some of the questions here...
Hub 1 USB capabilitiesHub 1 USB capabilities
SilverE
Well I did try to RTFH but I misread Help A-Z as all one item, and clicked on the A-Z part: and under U there is no mention of USB, just uPnP Sad
So the Hub should accept NTFS, but it doesn't specify a size limit, partition style or server mode (or disk sector size - another possible parameter). One of more of those stops my disk from working: prime suspect is its 5TB size. There's still a lot of trial and error.
