Accessing Snom VOIP base station through Hub Two
DaveKennedy
Hi
I want to use Snom M9 VOIP phones but can't access the base station through the Hub Two router. Using the allocated IP address I just get the 'This site can't be reached' message whatever way I try to connect.
I can connect and configure the base station using a Vodafone router (I've just moved from Vodafone to Plusnet).
I've tried changing various security settings in the Hub Two but so far without success.
Can anyone suggest what I need to change please?
Dave
6 REPLIES 6
Fixes: 585
Re: Accessing Snom VOIP base station through Hub Two
Is the base unit getting it's IP using DHCP or does it have a manually assigned address ?
DaveKennedy
DHCP at the moment.
Fixes: 585
In that case, there shouldnt be a problem. IIRC the default DHCP range for the HUb 2 is 192.168.1.64 to 192.168.1.200.
What IP address is the M9 getting ? You should be able to check it using the handset ( page 5 of the Admin guide here https://www.exteradirect.co.uk/download/product/002358/AdminGuide_snom_m9_en.pdf )
DaveKennedy
I think I've just sorted it. Although I was selecting DHCP that selection wasn't being saved.
I've just gone through the setup again and now I can connect, IP 192.1.168.66.
Many thanks. You pointed me in the right direction.
Fixes: 585
Glad its sorted.
greygit1
