5ghz WiFi isn't working.
- My Router
- 5ghz WiFi isn't working.
28-11-2021 1:15 PM
Although all my devices can see the 5Ghz network from my Hub One router, they can't connect to it.
Restarting the router resolves this for a while, but then it returns to being unconnectable.
Just switched from BT and already having issues day one!
Message 1 of 3
(1,432 Views)
2 REPLIES 2
Re: 5ghz WiFi isn't working.
28-11-2021 2:33 PM
@reeves90 Welcome to the forum.
Do you still have your BT Hub? If so use that. The full instructions are here but ignore the first steps as there is no need to factory reset it. https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/m-p/1587673#M85...
Message 2 of 3
(1,422 Views)
28-11-2021 5:45 PM - edited 28-11-2021 5:45 PM
Message 3 of 3
(1,399 Views)
