5Ghz now on router - OK to use or extra charge?
DRMLM
Hi - non techie person, so possibly silly question to some!  See that on my broadband connections now I have the option of a 5Ghz connection.  Would seem to be a lot faster, as expected.  Is this standard/included in Unlimited fibre extra package or does it cost more to use?  Thanks
2 REPLIES 2
Fixes: 480
Re: 5Ghz now on router - OK to use or extra charge?
@DRMLM
There is no charge for using the 5GHz hub wireless channel Don’t confuse it with the  5G mobile phone service.
Either wireless channel on a hub will not go any faster than the hub connects to the BT infrastructure, which is what you will get if you connect to your hub using an Ethernet cable.
DRMLM
Thanks for prompt information!
