5GHz Connection problems
- My Router
- 5GHz Connection problems
17-02-2020 11:35 AM
Hi
I am having problems trying to connect to my 5GHz connection.
I get an error message saying incorrect password, but its not!!
I've tried changing the password, it still will NOT connect.
I am running:
Re: 5GHz Connection problems
17-02-2020 12:17 PM
If you look on the router board the very first post relates to this and gives you and the many others in the same situation the means to report 5GHz wifi problems to a senior Plusnet staffer.
17-02-2020 2:10 PM
Moderators Note
This topic has been moved from Fibre to My Router.
17-02-2020 5:10 PM
https://community.plus.net/t5/My-Router/Hub-One-5GHz-WiFi-issue/td-p/1696363 is the same problem. It is a long thread but summary is:
Hub 1 router has a problem with the firmware.
Plusnet are aware of the problem but still send out the router
The only successful work around (afaik) is get your own router.
