Using TP-Link Deco with Plusnet Full Fibre 300 (Own Router Setup Help)
GIIBJ
Hi everyone,
I’ve just joined Plusnet Full Fibre 300 and I’m planning to use my own router setup instead of the Plusnet Hub.
My current setup is:
Openreach ONT → TP-Link Deco mesh system → devices
I was previously with BT and had the Deco connected directly to the ONT using PPPoE, and everything worked fine.
I understand Plusnet also uses PPPoE, but I’m just looking for confirmation from anyone already using their own router/mesh setup with Plusnet FTTP.
Could anyone confirm:
* The correct PPPoE settings
* Whether VLAN 101 is needed
* What the Plusnet broadband username/password normally looks like when using your own router
* If there’s anything specific I need to do on Deco systems
Also if anyone has experience using Plusnet with streaming devices like Fire Stick over Ethernet, I’d appreciate any tips.
Thanks Smiley
4 REPLIES 4
markhawkin
Champion
Fixes: 21
Re: Using TP-Link Deco with Plusnet Full Fibre 300 (Own Router Setup Help)
Username is
[email protected]
(to state the obvious it's the account name you use to log in not what I've written above!)
Password is
the password you use for the member centre
MTU
1492
I can't immediately think of what else the Deco might want.
No
See above
I don't have a Deco so I can't give an opinion on this.
If you have it working with BT I think the only thing you should need to change is the Username and Password (BT domestic service is a generic username and password whereas Plusnet is account specific).
With the username and password it should "just work".
Fixes: 478
@GIIBJ
The VLAN should be disabled or left blank. The VLAN setting is handled by the ONT.
Fixes: 147
@GIIBJ
On my TP-Link router the MTU setting is 1480, you might not see any noticeable difference if you change it to 1492, I didn't.
Worth noting much of the network infrastructure is shared between the BT group comms providers (EE, BT and plusnet), so all is required is to change the Internet (broadband) username and password pair, nothing else should need to be looked at.
markhawkin
Champion
Fixes: 21
The router I use has a test function for MTU and that suggested 1492 as the correct value.
It seems to work OK!
