Upgrade delayed
offan
Upgrade delayed
Hello,
Yesterday was my activation day for my fibre FTTP upgrade but it had to be cancelled/delayed as the router still wasn't here.  The router is now here and I'm just wondering how I go about re-organising an engineer visit?
Thanks.
4 REPLIES 4
adamwalker
Fixes: 223
Re: Upgrade delayed
Hi there @offan can you send over a PM with your username please so I can look into that for you? - Adam
 Adam Walker
RealAleMadrid
Fixes: 68
Re: Upgrade delayed
@offan  Don't see any reason why not having the router would cause the installation of FTTP to be cancelled. Who actually cancelled it? The ONT could be installed and tested with engineers equipment so it would be ready to go when the router arrived. You could also use a wired PC direct to the ONT as a temporary broadband connection.
It wouldn't be problem for me as I can see 4 or 5 routers lying around right now in my "office"😁
offan
Re: Upgrade delayed
HI adam i sent you that PM
MatthewWheeler
Fixes: 503
Re: Upgrade delayed
Hi @offan
Adam isn't in at the moment so I'll respond to the PM you sent on his behalf
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
