Support ticket on FTTP availability
RobPN
Fixes: 15
Re: Support ticket on FTTP availability
@richardt wrote:
It comes from the opposite side of the street, however those poles aren't fibre enabled.
@richardt wrote:
I'm at the end of a terrace of three houses, the other two have FTTP as they have line of sight to the pole, unfortunately for me there's another house in the way. They've known about it for nearly 10 months, frustrating!
I'm wondering if the pole your copper drop-wire comes from is an Intermediate pole, in which case it (and possibly even if it's not) could possibly be used as such for the fibre cable.  i.e. the fibre cable would be connected to the CBT on the pole which does not have line of sight to your house, across to the pole which carries your copper drop-wire, then to your house.
Fixes: 1,495
Moderators Note
This topic has been moved from Full Fibre to My Order
