Router
- My Order
- Router
Router
03-12-2020 12:41 PM
Re: Router
03-12-2020 12:47 PM
Take a look at the instrcutions in this thread https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/td-p/1587673
Re: Router
03-12-2020 1:06 PM
Re: Router
03-12-2020 1:08 PM
try connecting to it wirelessly . The default SSID and password should be on the back of the router
Re: Router
03-12-2020 1:10 PM
Re: Router
03-12-2020 1:19 PM - edited 03-12-2020 1:21 PM
Did you follow the instructions in para 2
Alternatively connect wirelessly by connecting wirelessly using the wireless SSID and Password found on the pull out panel on the rear of the router. Then enter 192.168.1.254 into the address (not search) field of a browser. The ‘Home’ page will appear.
if using wireless then you may need to reconnect before executing step 3
3 Leave it a couple more minutes then log in by entering 192.168.1.254 into the address (not search) field of a browser. The 'Home' page will appea
Re: Router
03-12-2020 2:04 PM
Re: Router
03-12-2020 2:59 PM
Dont connect the DSL line until after you've input the username/password
Re: Router
03-12-2020 4:01 PM
It keeps saying domain name is wrong and wont save
Re: Router
03-12-2020 4:08 PM
In that case I suggest you try posting on the main thread https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/td-p/1587673/pa... for advice
