Router dispatch for new customer
FIXED- Subscribe to RSS Feed
- My Order
- Re: Router dispatch for new customer
02-09-2025 7:56 PM
It says I should get the router before this but it’s not been dispatched yet? Will it even be here by Friday? 🙈
Thank you
Fixed! Go to the fix.
02-09-2025 8:01 PM
@Laurenedwards92 New Hubs are despatched via RM Tracked 24 to arrive a couple of days prior to a confirmed installation date. Has your installation been confirmed?
02-09-2025 8:03 PM
02-09-2025 8:09 PM
In that case check https://www.plus.net/member-centre/login?p=search for any open (or closed) tickets on your account.
02-09-2025 8:16 PM
02-09-2025 8:22 PM
OK. Incidently, I am a little surprised that you have been given a confirmed installation date only five days after placing the order. If it isn't a rude question, are you moving from another ISP, or is this a true 'new installation'?
02-09-2025 8:26 PM
I had the text explaining the installation is on Friday 05 sep between 8am - 1pm at such and such an address, explaining what is being done and reply to confirm. Replied yes and then had another text to confirm
“The engineer appointment to activate your broadband service is confirmed for 05/09/2025 between 08:00 - 13:00.”
02-09-2025 8:35 PM - edited 02-09-2025 8:35 PM
Thanks. You are lucky, it usually takes a little longer for PN to arrange. I a bit bemused that there are no tickets on your account, but if you have the confirmation message, that's OK.
As I said, the Hubs are sent RM Tracked 24, so should be despatched tomorrow - you will receive a text/email confirming despatch and giving a tracking number.
You could always call them tomorrow (0330 123 9123) to check.
02-09-2025 8:36 PM
I’ll keep track and phone them if no change. Thank you
03-09-2025 1:06 AM - edited 03-09-2025 1:07 AM
Hi jab1, just not to start a new topic:
I've got confirmation on OpenReach Engineer coming on 9 September, 1pm-6pm (The order placed and paid on 30 August).
It's a new installation, we have no Internet there. The status is:PlusNet.pngFrom your practice, if installation is taking place on Tue, then I should receive the router on Mon max. So, when should it be dispatched then to make it to Monday?
Ta,
Kate
03-09-2025 7:02 AM - edited 03-09-2025 7:04 AM
@kateishere If your installation is Tuesday, I would guess the despatch would is tomorrow at the latest, or possibly, today.
04-09-2025 12:46 AM
Thank you for the quick answer.
Unfortunately there wasn't any despatch today, I really hope it will be tomorrow.
From your experience, Do I need to be at home at this time or do they put the router through the mail slot? Will it pass through the mail slot? If not and I wont be at home, Do they just leave some notification about this? Or how it works?
Thank you in advance;)
04-09-2025 7:06 AM
@kateishere There is still time for your Hub to arrive before your installation - it is despatched using RM Tracked 24.
Providing your letterbox isn't a tiny one, the package should go through. If, for any reason, it doesn't get through, it will be returned to your local delivery office, and they will leave a card which will enable you to collect it from there.
08-09-2025 10:19 PM
Thank you so much for your help. I've received the router.
One last question.
The engineer will install a media convertor tomorrow as I understand.
In case he says "let's try to connect the router". I should wait for an activation sms/email from PlusNet. Correct?
And to test the line tomorrow what device should I have? A laptop with an ethernet port? Or a smartphone with Wi-Fi should be enough? Or the engineer will do it on his own?
Regards,
Kate.
08-09-2025 10:29 PM
The engineer will install an Optical Network Terminator (ONT) on an inside wall. You connect the router to this via an etherent cable.
You can do the initial check to confirm it's working via either a wired device or WiFI.
However, speed checks are always best done on a wired (ethernet connnected) device to ensure no outside interference.
- My Order
