Product upgrade hasn't happened (From 300 to 500)
sw4mpl0rd
Hello all,
I was supposed to be upgraded from Full Fibre 300 to Full Fibre 500 today but it hasn't happened yet.
Yes, I know I'm impatient!
I'm stuck on:
An error has occurred
You can't change your products for the moment, you already have a product change in progress.
Is this usual or have I got lost in the system somewhere?
4 REPLIES 4
RealAleMadrid
Fixes: 68
Re: Product upgrade hasn't happened (From 300 to 500)
@sw4mpl0rd It might happen later today, the message would suggest the change is still pending. If it hasn't completed by tomorrow try calling support.
Fixes: 1,491
Moderators Note
This topic has been moved from Full Fibre to My OrderW
MatthewWheeler
Fixes: 503
Evening @sw4mpl0rd
Looks like the upgrade was completed on our end the day after your post.
Is all working okay now?
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
sw4mpl0rd
Yes, all good. Thanks!
