Problems switching to full fibre
Patience
I tried to switch from my current product (unlimited fibre extra with line rental) to full fibre 74, but got the following message:
We were unable start your order, this appears to be caused by the products in RBM not matching the active products on the account please confirm this and raise accordingly if this is the case.
Can anyone tell me what this means, please?
8 REPLIES 8
Fixes: 466
Re: Problems switching to full fibre
Moderators Note
This topic has been moved from Broadband to My Order
Fixes: 105
@Patience
No idea - you'll need to wait for a staff member to pick up the thread.
Or you could try phoning the PlusNet Customer Options Team on 0800 013 2632 - remember it's a bank holiday.
Fixes: 105
@Patience
If you do phone do let us know what it means in case it helps someone else in the future.
Fixes: 558
I believe RBM is the acronym for the billing system. The message would indicate there's a mismatch between what products are showing on the account and in the billing system
Patience
Hi Brian
I received this reply from a superuser:
I believe RBM is the acronym for the billing system. The message would indicate there's a mismatch between what products are showing on the account and in the billing system.
TheMightyAJ
Fixes: 126
Hey @Patience,
I'm very sorry to hear that you've run into this issue. This might be an issue with the account itself, but I'd recommend giving our Customer Options Team a call to see if they can put the upgrade through on their end. You can reach the team directly on 0800 013 2632 between the hours of 8AM-8PM from Monday to Friday, 9AM-7PM on Saturdays and 9AM-6PM on Sundays.
 Alex H
Patience
Hi Mighty AJ
Thanks for contacting me. I had limited time available to sort this issue so decided to just renew my existing package and forget full fibre.  Even though the process of renewing my contract indicated that full fibre was available to me, days after renewing my existing package I received a message saying that full fibre was 'now available' in my area.  I'll try again in 18 months' time. Thanks to you and the community for your comments and feedback
Fixes: 558
@Patience there's no need to wait until your contract is up. Once you've got more time , give Customer options a call. If you upgrade to full fibre then I'm sure Plusnet Will waive any early termination fees on your current contract.
