Router has not arrived for full fibre engineer install tomorrow
richminust
As above. Will the engineer have it with him?
Thanks in advance.
5 REPLIES 5
Fixes: 558
Re: Router has not arrived for full fibre engineer install tomorrow
Will the engineer have it with him? No, the engineer will be Openreach ( or contractor ). They do not supply the router.
Do you have an existing router ?
from your previous posts , I guess it's a Hub One ? in which case you can use that until the Hub 2 arrives. Just connect an ethernet cable from the ONT to the WAN port on the Hub one and remove the existing cable from the DSL port
richminust
Thank you. Yes I have a hub one. Glad it can be used in the interim.
adamwalker
Fixes: 223
Hi there richminust, I'm sorry for the delay in getting the new router to you, has that arrived yet? - Adam
 Adam Walker
richminust
Hi Adam. Yes thank you, it arrived this morning.
adamwalker
Fixes: 223
Great, I'm glad that's reached you, do let us know if you encounter any issues and I hope everything is working as it should be.
 Adam Walker
