Plus Net Assuming I have a ONT Device
greathassan
Re: Plus Net Assuming I have a ONT Device
@MisterW Thanks for this. I just checked the UPRN number for the first floor flat and it gives a different result.
On the results it says "FTTP is not available.".
However for my flat (ground floor flat). It gives following results:
"Our records show the following FTTP network service information for these premises:-Single Dwelling Unit Residential OH Feed with Line of sight problems Trees.
ONT exists with active service. A spare port may be available or a single port ONT may be swappable to a multiport ONT. A new ONT may be ordered."
Fixes: 383
Looks that way to me, too @MisterW .
greathassan
I am thinking maybe that someone from the top flat got the connection, but UPRN number for the ground floor flat got registered for that, hence the confusion.
Fixes: 580
@greathassan that's confusing!. In that case,  I think you're just going to have to wait and see what the engineer makes of it!
edit:
That was my thought, or it was installed before the conversion to two flats and the downstairs flat now has the original UPRN
Fixes: 117
@greathassan
There may well be a records mis-match on the OR database.
I think you're just going to have to wait until the OR engineer shows up and has a look, unless a member of staff picks this up and checks records "behing the scenes" so to speak.
When the engineer is there you can speak to them regarding the location of the ONT in your property - just be aware it needs to be within one metre of a power source.
Also, I assume you have your landlords permission to install FTTP - might be another hicup once the address is sorted if OR need a wayleave signed.
Fixes: 383
@bmc The OP is in a property which has been converted to two flats - the upper on has already had FTTP installed - see pictures - but theirs has no OR installation.
