Ordered 11th June, Activation date 1st July, still nothing.....
drpaulbennett
As the title says, I ordered my PlusNet subscription (moving over from BT) on the 11th June, had an email stating that activation will take place on the 1st July, followed by a message indicating there's been a delay.  I've been sent my router.  And since then, nothing......   Anyone from PlusNet able to help?
I need to know when the switchover is going to happen so it does not affect my work.
Also, am I right in thinking there is an entitlement to compensation for delayed installation?
Any advice welcome
2 REPLIES 2
Fixes: 374
Re: Ordered 11th June, Activation date 1st July, still nothing.....
If you have received your PN Hub, this would indicate that whatever the delay was has been cleared -- they are usually sent out to arrive 3-5 days prior to activation, you appear to have received yours early.
If you want further details you will have to call PN - staff support on here is patchy.
Fixes: 110
@drpaulbennett
You can use the following link to see if there are any open / closed questions that can shed more light on the matter.
https://www.plus.net/wizard/?p=search
