Openreach
Galadriel
Re: Openreach
Hi @marcsnu15,
Unfortunately we don't have that information from Openreach, it might be worth checking with your neighbours directly if Openreach have been in contact. Our next review date is the 8th to check in with them to see where we're at.
marcsnu15
Re: Openreach
Is there a number that I can contact Openreach? My order was delayed as I needed permission from a couple of neighbours living at 12 and 13 but I've spoke to them both and they both have gave me permission for the engineer to come and progress with the order
Fixes: 387
Re: Openreach
@marcsnu15 - No, you have to go through Plusnet.
Fixes: 480
Re: Openreach
@marcsnu15
It might be splitting hairs but my reading is that OR require your neighbours to give OR permission, not for you to tell OR that you have your neighbours’ permission. OR might not believe you.
marcsnu15
Re: Openreach
Just had my full fibre connected this morning. Any chance how long it would take before I receive an email saying the services are up and running? Or can I just turn the hub on straight away?
willcutforth
Fixes: 113
Re: Openreach
It can take anywhere up until midnight to turn on but give it a couple of hours and all should be sorted.
 Will Cutforth
RealAleMadrid
Fixes: 68
Re: Openreach
@marcsnu15  I would say give it a try, there's a good chance it will work. If not get onto Plusnet, they may need to activate the account at their end.
marcsnu15
Re: Openreach
Couldn't remember how to make a new topic
But my issue is that I've just received an amount of compensation I should be owed due to delays however I have worked out that I should be owed a lot more than what I've been quoted, how do I make sure I get the correct amount owed?
MatthewWheeler
Fixes: 503
Re: Openreach
Hi @marcsnu15
We have to give it a full 30 days from when the order was completed before we can chase this up further as it can take that long for all of it to be added
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
